I use windows movie maker to get the video from my DV Camera i always set it to DV-AVI but when i get the video it is DV-AVI type 1 i want type 2 so i can use virtual dub so i've been using the DV Type 1 to DV Type 2 Converter.
Is there a way to just get type 2 from windows movie maker? Theres nother in settings about it. Using that DV Type 1 to DV Type 2 Converter messes up the audio at the end.
I have done a little research into this and have discovered that WMM does not support DV AVI type II.
You will have to capture using another software type. I have been told that there is not a great deal of difference between the two in terms of quality.
I am currently testing out a few other editing softwares out there but am not ver far down the line. I will have a better ideaover the next few days. -
Thanks for the help i checked out the two links above they look ok but do you know of any other programs that have device controls to?
Thanks again! -
thanks thouse work
One more question about virtualdub after you cut out the parts you don't want how do you save them without loosing any quality?
Originally Posted by David9799
Audio->Direct stream copy
File->save avi
Recovering a corrupted AVI from a digital camera
By debest in forum Newbie / General discussionsReplies: 12Last Post: 20th Oct 2015, 05:34 -
Is there a way to transfer to computer from video camera beside .AVI
By sj022698 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2011, 09:06 -
Need help with AVI Spy Camera
By idealhusband in forum Video ConversionReplies: 3Last Post: 29th Jul 2010, 01:12 -
Can't transfer .avi file from camera...
By Captain Satellite in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 12:32 -
Combing in AVI files when transfered from camera to PC
By ChuckvB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th May 2009, 07:03
