i tryed the avi on my dvd player. the sound and picture dont go toghter. is there something i could do to make it right.
any help much appreciated
Is it in sync when you play it on your computer? If so, then I can't help because it's your player. If it is out by a fixed amount then...
You can change the audio delay with virtualdub. Load the avi and set video to direct stream copy. Under audio select full processing mode then audio>interleaving and adjust the audio delay (either + or -). Back in the main window you can play the file and fine tune your delay as necessary. Select a compression type under audio>compression or just leave it and your audio will be uncompressed wav (very large). File>save avi."Art is making something out of nothing and selling it." - Frank Zappa
AVI2ISO sound problem
By Belfour in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 13:37 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
