hi, i'm using gordianknot to create an avs file that includes vobsubtitles to be encoded to svcd. but however after I load up the avs file, the vobsub always use the first subtitle in the list, but i want to use the 5th subtitle which is english to be encoded to svcd. is there anyway i can choose which subtitle to use rather than have it default the 1st subtitle in the list? thank you
okay i found the answer, you have to edit the idx file to change which sub language to be displayed
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
are subtitle displayed selectivily from a single subtitle track?
By rakan in forum Newbie / General discussionsReplies: 11Last Post: 21st Dec 2009, 19:21 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
