  1. Hi all,
    I have a SVCD PAL movie which is 480x576 in resolution and I want to convert it to DVD. Should I resize to 704x480 or 352x480?
    Jan 2001
    Brisbane, Australia
    Both of those resolutions you specified are NTSC not PAL
    you should be going to either 720x576 or 352x576
    I would suggest going to 352x576 though - but either way will reduce quality a bit
  3. My bad! Forgot to specify that I am converting it also to NTSC, and thus that is why I used those resolutions. So, I should convert to 352x480? Better reduce than enlarge?
    Jan 2001
    Brisbane, Australia
    ok fair enough about the NTSC bit
    I would reduce
    sorry I can't help you with the conversion process
    I'm PAL all the way
  5. Thanks for your help buddy!
