I have a dvd which I would like to put the music on it on a cd so i can play on my stereo.
Is it possible to do this and what software woud I need??
thanks ppl![]()
use virtualdub to extract the audio into a wave file.
use musicmatch to burn the wave files to cd. -
An alternative approach which is useful if the original is a music DVD:
1. Use DVD Decrypter (or whatever) to rip the DVD, with the option set to split vob files at every chapter. for a music DVD this will give you a vob file for each song.
2. Run each vob (or those that you want on your CD) through DVD2AVI.
3. Use the WAV files from the above (now one wav for each song) to compile an audio CD using any number of applications.
At stage 2 you can rename the wav files and number them to make compiling easier. -
Thanx for the advice i'll give it a bash
It's a U2 dvd so not sure how it wil turn out.
Thanx again,
P.S. Anyone else got alternatives be glad to hear them.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
