I have a Dvico FusionHDTV DVB-T pci card to watch hdtv on computer. I can capture the HD to hard drive as .tp files. The software includes a convertor program which supposedly converts the files to dvd or mpeg2. However all burning/ authoring software I have tried seems to have problems opening or accepting as valid files.Can anyone help with ideas of how I can put the captered files on to dvd.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
īDon't know what type of files and resolution you are referring to but if you have a conversion utility the files that are beeing prepared by it should be 100% compatible. Dvico is not a first rate manuf. so you may have trouble getting some support but I would fire off an email to them if I were you.
Mainconcept MainActor 5.1 has the ability to open and save to all sorts of formats incl. HD. get the demo and check the properties of your files, analyse why there is a problem. That is all I could suggest at this point. -
procoder also will open all types of transport streams - you dont need to even convert them first ..
if they are converted to mpeg - main concept and tempgenc will open them ok"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You can try a few other converters. I've used this one with good results. They will just convert TS streams to MPEG. They will not make them DVD compatible. If your stream is 1920x1080, you'll still need to resize it to a compatible resolution.
http://www.eecs.umich.edu/~balazer/HDTVtoMPEG2/
The source files are listed there if you need to recompile the code.Impossible to see the future is. The Dark Side clouds everything... -
Maybe this could be helpful:
http://www.codecpage.com/DVB.html.
Cheers
Converting a 4:3 project for a 16x9 HDTV
By jeffgrooves in forum Video ConversionReplies: 2Last Post: 24th Aug 2010, 13:25 -
Converting PAL DVDs to NTSC For HDTV
By Startropic1 in forum DVD RippingReplies: 8Last Post: 9th Jun 2010, 09:34 -
Converting .ts/avc HDTV files to .avi
By Kull in forum Video ConversionReplies: 2Last Post: 8th Feb 2010, 19:57 -
Capturing HDTV and Converting/Exporting
By eighteesix in forum CapturingReplies: 1Last Post: 26th Mar 2009, 02:20 -
Converting TS Files with HDTV Content
By AlexTimaios in forum ffmpegX general discussionReplies: 2Last Post: 19th Aug 2008, 01:56
