After searching for the best possible guide, I have heard many people having success with AutoGK, and Guardian Knot. I personally have had no luck with converting my first dvd into divx/xvid using either guide.
After following the prompts carefully, I end up with 2 videos in my output folder. One is twice the size of the other, but both are the completed encoded movie. When I play both on my pc, they look perfectly fine; however, when burning to dvd and playing in my divx stand-alone player, the picture is all distorted/fuzzy/garbage.
I understand that resultion/bitrate makes the video become great or poor quality, but even after I follow the correct steps (suggested from the guides), the video is still garbage.
I have a friend who download's a xvid/divx movies every once and a while, and his movies are PERFECT. Well, not 100%, but they are 100% than what I can produce.
Any suggestions?
Results 1 to 15 of 15
I guess you are encoding Divx to a format that is not supported by your Divx set top player - it could be as simple as that.
Go back to the manual of your player and check what formats are or are not supported, and make sure you are using the right codecs / parameters when you encode. Gordian Knot or AutoGK are good tools.
Better even, post the name of your player here and I m sure some other users will offer some advice as to what works/does not work with it. -
My player is the Philips 642. It is one of the most popular ones out there that plays Divx.
Any other comments? -
Hello,
I don't know much about settop divx players. However, you might try buying a real divx converter. There's a ten dollar dvd ripper program you can pick up at a bestbuy for decent results. Or of course for 30 or 40 bucks you could buy dr divx for the best results (www.divx.com). Good luck.
No dvix/xvid program that you buy will give you any better results than the readily available freeware programs can give you.
Have you searched various forums for anyone with experience encoding spicifically for a Philips 642? I agree with aguillon, most likely it is that your settop doesn't like some of the settings you are using (as is proved by the fact that your PC plays them fine.)
Do you know if you are using/your settop supports B-frames, GMC, Qpel, etc. Those are the most likely culprets.
-Suntan -
Wulf, no I don't believe I clicked that option. I will have to re-install and try again.
Do you find when you back your dvd's you are able to compress most of them to 700mb? Do you configure any of your own manual settings?
My friends pirated movies are unreal. I can't believe the quality; however, it can't be too hard to do myself.
Time to give Autogk another shot. -
Wulf, I just finished encoding the movie WITH ESS option, and it did work. Thank you.
Here's my current problem.
After taking my fullscreen movie (would widescreen make a difference?) I only selected the file to fit 1 cd (700mb), but once finished the final product was only a mere 580mb. I burned that to dvd and tried it in my philips player and the quality was 'poor', but 80% better than what I originally had.
So, with that said, I'm trying to get 'good quality', and of course you know what that means, but i'm trying to squeeze on 5 (4 is the minimum) onto dvd. Before I go ahead and re-encode it again, would it be best to select a perferred max size, which will be 1400 mb? or 75% of the original quality? If I would choose 1400mb, will the final product BE 1400mb? or is that just a 'guesstimate' and will most likely be smaller in size?
Last thing, would it be best for me to use manual settings? Doesn't AutoGK use (what you stated) automatically when encoding?
I'm just trying to find the best way to convert, but at the same time it doesn't have to be the simplest.
Thanks for your help! -
I just started playing around with autoGK (have used the full blown Gordian Knot in the past) and so far it is making SUPER nice looking Xvid files for me.
I've been using the custom size 1400MB (which is about 1.4GB) which will give you one single file. Sometimes it is ever-so-slightly less than 1.4GB (smallest yet is 1.32GB) and sometimes just barely over (like 1.41GB).
I'm thinking of getting a Philips 642 as WALMART has them now for only $57 and change.
I've been doing some DVD back-ups and doing each DVD twice ... once with the ESS option for stand alones and again with the MTK/SIGMA option for stand alones.
In my opinion ... on the computer ... the ESS encodes look better. I wonder why?
I can see how autoGK may be "too automatic" when it comes to a non-progressive source. So far I've done 5 DVD discs with autoGK but all have been NTSC 23.976fps progressive. Nothing "complicated" like IVTC or hybrids.
- John "FulciLives" Coleman
P.S.
I've been using FIXED WIDTH = 640 since I am a "quality" freak. I also have been using the original 5.1 AC-3 audio. So far everything looks fine. I've done one 640x480 DVD as well as "ultra WS" 640x272"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
My friends pirated movies are unreal. I can't believe the quality; however, it can't be too hard to do myself. -
At the risk of coming accross as a total ASS, why go thorugh all that and not simply back up to DVD r directly. DVD r are about 30 cents a piece and it takes me about40 total from rip/shrink irf neede and burning to disk. I also have a phillips but I could not come up with a reaso to purposely take a perfectly good DVD and degrade it to a Divx just to be able to fit several movies to a DVD r and watch them on my phillips. The phillips is a dvd player first. It just happens that it also plays Dvix and Xvid. I would be like buying something just because you have a discount coupon and not because you really needed it.
I appologize but butting in but it justs makes me wonder whenever I see postings about DVD to divx convertions. Even though I once did them, I soon discovered the better backup option.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by X-treme
Originally Posted by Paul_G
I'll allow this to continue on the premise that the conversion of DVD --> MPEG4 is for a legitimate purpose. -
Originally Posted by SuntanC2D 6300@3.21Ghz|Vista Ultimate x64|P5B-Dlx Wifi|Transcend 4 GB 800 Mhz|XFX 8800GT 512 MB Alpha Dog Edition|Samsung 19" 940BW|1.5 TeraByte Storage|ASUS SATA DVDRW|Altec Lansing ATP5|APC 800 Smart UPS.
1400mb is a more realistic option for keeping the quality up (keep ac3 sound)
Actually you have to manually select something slightly (+/- 1mb) other than 1400mb otherwise AGK will give you two perfectly formed 700mb avi files, perfect for burning to two CDR. Incidentally they wont be two equal halves, timewise. 642 afaik is a perfectly good machine. Personally I want a modix 350 (not available in Uk tho) ;- (
NNb is DTS sound dead/dying ?? not many movies have it today..Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
