I have been watching some dvd's and i noticed that many have cool movies (animations) in the beginning and the after the movie (animation) is finished the buttons fade and i can select video clips.I was woundering how to to something like this,it looks realy cool...
I have a video clip i want to use soo if someone nows how to please explain it for me.![]()
Results 1 to 9 of 9
You need an authoring program that recognises chapters in a motion menu, and that can be programmed to play up to a certain point before the menu sub pictures kick in. I believe scenarist can do this, but I don't know of any others.
Your other choice is to split the clip into two pieces - before menu and menu. The before menu goes into the first play slot, the menu then follows. You may have a slight pause between the items though. This is usually most noticable when the sound breaks, but you can hide this with a fade.
Disolves between menus are done in a similar manner, with seperate clips playing between menus. DVD Lab can do this and create the transitions for you. -
How ironic.........I just did one of those for my son's Baseball team.
guns1inger hit the nail on the head. I used DVD-Lab to make mine. I made an animated clip and at the last few seconds, I faded in the text links. I then made the motion menu with using the same image and text. I then created butons shaped as Baseball bats that are invisable normaly. They are only visable when the selection is activated.
I set the 1st animated clip to play before the Menu. It then goes right to the menu, where you can select the video you want to watch. It looks real cool actually.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Download an evaluation version of DVDLab, if you don't already have it, and then go to the tips section at Mediachance.com to download the motion menu tutorial.
It's so simple that I did my first motion menu while following the steps of the tutorial online (and browsing through dvdrhelp while encoding)
The more I learn, the more I come to realize how little it is I know. -
Okey because of the page is down i try to explain how i want my menu and dvd to work..
1: i have a video klipp i want to run when the dvd start,here is the clip and in the end i want it to stop.
2: In the center i want the video to be shown as motion and i want a button where i can select next video soo on..Something like this ( the blue part is where the video is going to be shown ) and under it im going to have a forward and backwad button soo i can select next video...
3: I want bakground audio while i select the videos,the audio file is already done and encoded for dvd lab.
Hope i explained well and that you understand how i want my dvd to work.Soo if you can show me step by step with pictures im forever grateful -
What you want is advanced video editing and Authoring. The problem is, you don't know what you're doing. Sure I could write a guide for it, but I don't have the time. Besides, I hate typing. I'm going to give you some advice on it, but you'll have to do some searching for the guides you'll need.
1) The link to the clip doesn't work. Import your clip into a good video editor like Premiere, then cut where you want it to end and export the last frame as a bmp.
2) Edit that bmp in a good image editor like Photoshop. Cut out the center like you want to make it transparent and save as a psd. Now overlay that psd on the videos that you want to preview. You should see the videos through the transparent layer. You can make the videos like 5-10 sec long. Do this for all videos you want to preview. Render each one out to Mpeg-2. These will be you motion menus.
To make the effect you want, you'll have to make "Switched Menus". Do a search for it on the DVD-Lab tutorial site.
3) you can have background music, but it will have to be a different file for each menu.
It's as simple as that......... if you don't understand, then you're in over your head and should just stick to simple still menus.
Good luck!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 08:23 -
GfD animation before menu
By michcio in forum Authoring (DVD)Replies: 21Last Post: 2nd Jul 2009, 09:07 -
3D modeling and animation?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2008, 08:58 -
animation to dvd
By J. Baker in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2007, 01:53
