  1. how can i fit two mpeg files thats 747mb and 741mb onto one dvd? using nero vision express 2 and the 2 files is just 1 movie,when i try to add them it goes over the dvd limit
  2. Good luck trying to make NeroVision Express 2 do anything specific.
    NVE-2 will re-encode anything you throw at it, and the user has limited control over the process. It might just reencode everything to its own concept of "DVD compliant" and leave you with a file that is 4 times the size of your DVD blank.
    If its a two part VideoCD that your making (a guess), there are guides to convert VCD to DVD without reencoding the video. It could save you alot of time, and disc space.
  3. TMPGEnc DVD Author probably should able to do that. Drag-and-drop both MPEGs into it, and you're done provided the files are DVD-compliant
