What is the recommended dvd burning software.
Is Nero 6 ultra a good one?
Would like to what is the preferred?
Nero is OK for miscellaneous burning, not a great encoder, though. I also use DVDdecrypter for image burns from DVDshrink. There's 35 burning programs listed in the 'Tools' section to the left if you want some more alternatives. I still use Nero 5.5.10.54 because I don't need all the 'extras' Nero added to the newer versions.
Sorry for the newbie question but what do you mean by image burn. I want to burn a data dvd just as you burn data cd's. I tried to use Nero 6 and I got errors. Is there a special way to do this?
Thanks -
With NERO, for data files on a DVD, I just use the DVD-ROM (ISO) selection and select the files to burn.
An image file is used to burn an exact copy of the original file with all formatting preserved. The burning software will not modify it, just burn it as directed by the image file. (More or less.)
best free software to burn dvd?
By sgbd in forum Authoring (DVD)Replies: 10Last Post: 17th Oct 2010, 07:57 -
Burn software issues
By RedGiant947 in forum MacReplies: 4Last Post: 27th Dec 2009, 04:52 -
Best software to burn my dvd files
By superJT in forum Authoring (DVD)Replies: 10Last Post: 18th Aug 2008, 20:35 -
Software to burn HD-DVDs
By indie1982 in forum DVD RippingReplies: 4Last Post: 8th Sep 2007, 13:36 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
