I understand it is possible to add subtitles to a movie while at the same time converting it to (e.g.) DVD or SVCD.
I like to try to diminish unnecessary lengthy testruns, so that't why my question.
If I use titlelab to create a file that can be read with QT, can then that same file be used with FFmpegx and (especially) will the timing be identical as to when if I had done the merge with QT?
You can directly add a .srt file in the Filters tab (remember to select "Decode with mplayer" too) without need of merging them on a Quicktime file first. If you want to test, use the "Preview" button at the top of the window to see the result without waiting for the encoding to finish.
Subtitles show format tags in movie
By laserbeak in forum SubtitleReplies: 7Last Post: 26th Sep 2013, 09:53 -
Handling Subtitles in Format Factory
By Shilar in forum Video ConversionReplies: 10Last Post: 30th May 2012, 14:50 -
Subtitles not showing in .mkv format
By Haramin in forum Software PlayingReplies: 2Last Post: 2nd Mar 2010, 17:38 -
.ass Format Subtitles With .wmv?
By NeoCyrus in forum SubtitleReplies: 4Last Post: 26th Nov 2008, 20:14 -
.mkv format to ipod with subtitles
By zps in forum SubtitleReplies: 1Last Post: 1st Nov 2007, 02:59
