I beleive I have finally decided on my software of choice.
IuVCR for capturing since VD is not an option with XP.
PicVideo compression
AVIsyhtn/VirtualDubMOD for filtering and cutting and so forth.
CCE for encoding.
I've read about AVIsynth being faster with YV12 color and some about a mpeg2dec file to help? What is the story with YV12 or YUY2?
I am currently capturing in YUY2. Should I change that to YV12? What is the mpeg2dec3 file for AVIsynth do? I want to make sure I have the fastest and most effecient setup before I dive in and do 21 tapes!
Thanks,
LS
The mpeg2dec3 if for reading dvd2avi .d2v files when you are opening VOB files w/ avisynth, since you are dealing w/ an AVI, you can ignore it.
I dont get your comment about not being able to capture w/ VD (I assume you mean VirtualDub) in XP. I do this all the time.
I found that AVISynth works faster then frameserving from VirtualDub, so I always use it.
I capture w/ YUY2, I remember reading that it gives some of the best results for picture quality.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Originally Posted by Ejoc
LS -
XP uses WDM drivers and VD requires VFW
YV12 will get you speed, but i believe YUY2 gets you a tad bit better quality. But try to capture with either uncompressed YUY2(not an option for many), or Huffy in YUY2 colourspace...
Formula:
Uncompressed YUY2+352x480 capture+AVISynth+CCE+DVDLab, produce the fastest and best results..
I can encode 1.5x realtime on a crappy P111 1ghz..
I believe YUY2 is a better capture colourspace than YV12. Not sure of the speed difference though.... -
I bought Ivan's capture program myself and used it for a while, but I gave it up in favor of VirtualVCR. I don't know if he's changed anything about in the last year or so, but I kept having audio synch problems when I'd capture stuff with IUVCR, and the dynamic resampling option in VirtualVCR solved that problem so I quit using IUVCR. Really nice program though, save for the synch issue.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
CCE, AviSynth and MP4 Question
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 31st Mar 2008, 11:19 -
MKV, CCE and AviSynth Question
By Maikeru-sama in forum Video ConversionReplies: 10Last Post: 14th Jan 2008, 16:35 -
Matted to anamorphic with aviSynth/CCE?
By Sephiroth666 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2008, 00:00 -
Questions about CCE, H264 and AviSynth
By Maikeru-sama in forum Video ConversionReplies: 18Last Post: 21st Dec 2007, 20:38
