  1. Hi
    im new to all this encoding and authoring
    ive got a 2h 15m movie that i have encoded and is in 2 halfs.
    every time i encode it trying to bring the size of the 2 files below the 4.3 gb mark for dvd author i can never do it.
    so what i want to know is what is maximum size my vob files should be.
    when dvd shrinking them so that i dont lose any quality from the encoded file ive done.
    or should i just use a half D1 resolution 352x576 and encode using max VBR 4000 to get the vobs around 5GB mark then shrink that way.
    or could i shrink a file as big as say 6GB-7GB without losing quality or much quality.
    thx
    why not convert to right size directly?
  3. thx for the reply ive figured out how to get a full 2h15min film under the 4.3gb barier.
    im using mainconcept 1.4.
    i was using dvd mpeg settings before in mainconcept and thats how it was making large files over 6gb when encoding big files.
    all i done was change the mpeg type 2 mpeg2 so i could edit some advanced settings.
    and changed the average bitrate to 0 and the minimum bitrate to 0.
    i put the maximum bitrate to full then all i done was change the quality control option to 3 rather than 10 and now a 2hour movies is only encoding to around 3.6 gb and i dont really notice any quality loss either,
