Is there a video capture card that will capture
audio at a sampling rate of 48 kHz?
Use an sblive to get the audio, but why would you want it... isn't CD quality good enough
sblive.... do you mean sound blaster and capture
at the same time of the video capture?
I want to do it with 48 kHz because that is the
standard for DVD and I'm doing a lot of DVD stuff
Capture Card With No Delay Input Capable of 720p+ @ 60fps?
By NeoCyrus in forum Capturing and VCRReplies: 34Last Post: 4th Feb 2011, 00:32 -
Modern consensus on best sub-$250 lossless AVI-capable analog capture card?
By Mini-Me in forum Capturing and VCRReplies: 31Last Post: 9th Jul 2010, 06:18 -
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
capture of S-Video and PCM 44.1 kHz at the same time ?
By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 15:16
