i have windows 2000 SP4, and XP Pro SP1. when I try running ifoedit 95 & 96, it crashes. i have a video (m2v) and audio (ac3).
the error I get is:
ifoedit.exe has generated errors and will be closed by windows. you will need to restart the program.
an error log is being created.
I can't find the error log.
which version are you using?
sometimes the newer versions are unstable - try using an older one... does this error happen the moment you start ifoedit?
try contacting the developing ppl - maybe they can also be of service...With all due respect... and there is respect...
AVIdemux keeps crashing
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 13:32 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 14:29 -
My Avidemux Is Crashing
By bigman70 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 11:54 -
MPV crashing
By SignedupGuest in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 15:38 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 05:54
