TMPGEnc Plus only uses ffdshow if the DirectShow Multimedia File Reader has the highest priority in Option -> Environmental setting -> VFAPI plug-in. Otherwise TMPGEnc uses the regular DivX/XviD codecs.
Anyway, I don't think uninstalling ffdshow will matter, but of course there are many versions of ffdshow. I always use the latest Athos build: http://athos.leffe.dnsalias.com/
If I install a build that causes problems I reinstall the previous build and all is well again. -
I honestly don't know if it will affect the quality, but you can always run a short test (use the Source Range in TMPGEnc to convert a small part of your AVI file). If you don't like the quality reinstall a better version of ffdshow. I like the latest Athos build a lot, but I don't convert divx/xvid to (S)VCD or DVD, I have a videocard with tv-out (much easier). I only use ffdshow for playback, haven't tried the other divx/xvid codecs in a long time.
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 05:11 -
AVI file and Video Decoder Configuration (ffdshow)
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 19:14 -
Best image quality as possible for AVI videos...FFdshow filter.Any ideas???
By fgtan in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Jun 2007, 15:17 -
TmpgEnc + mkv (renamed to .avi) + .ass + ffdshow - DirectVobSub = Insanity
By Sumgai in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 00:21 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
