Hi, I just found this program not long ago, and I'm not to familiar with it.
I'm trying to convert some DivX movies to DVD with the DVD QuickSetup in the ffmpegX 0.0.9L.
I have two problems.
First after the conversion is made and when I trie to play the Video_TS folder the audio isn't the "default" channel. I must change de audio track to the second one to have the audio playing in the DVD player. Only if I select passthrough in the Audio Codec popup menu I have the audio right away when I insert the disc on the DVD player. Is this the right way to encode audio (passthrough insted of .AC3)?
Second, the folder Video_TS after the DVD QuickSetup encode as only +- 2.2 GB when a DVD disc have 4.7 GB. This way the lost of quality is bigger. What can I do to make a bigger file after the encoding?
Thanks major for this program that I'm think it's a buying one.
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 1st Nov 2011, 00:11 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 18:53 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 09:14 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 05:13
