I am going to start putting some tv episodes I have on VHS to either DVD's or SVCD/VCD. Anyway, I was wondering if there is any point to putting these tv episodes onto dvd since there is no gain in video quality? Is the only advantage to putting my VHS tapes on DVD's is that they just hold more? Am I off base on this? Any insight would be appreciated.
Putting them onto standart DVD will preserve more quality then standart SVCD. This is the quality gain.
In most cases, VHS or TV ep. at full blown DVD resolution (720x480) 5500-6000 avg bitrate is pretty much a waste. The same quality can be had using 1/2 D1 (352x480) and 3000-4000 bitrate, with a high quality encoder. TV and VHS have a low resolution to begin with.
BUT if your using a hardware mpeg encoder, 720x480 may look better because of the scaler the encoder uses. Since it's hardware, there is little time used to try different resolutions and bitrates.
DVD allows for 352x240, 352x480, 704x480, and 720x480. Instead of 1 ep per CD, you could have 7-8 eps per DVD, that's one advantage. -
...in NTSC-land. If you're in a PAL region, 240 becomes 288 and 480 becomes 576.Originally Posted by disturbed1
My opinion on advantages:
1. A DVD can hold more, lots more.
2. Authoring DVD's with something like TMPGEnc DVD Author gives you menus and chapters, each with their own still or motion pictures - better looking end product - and is pretty easy to use (also popular so loads of guides / people who can help).
3. DVDs are newer technology, and VCD / SVCD may fade out of favour as DVD burners get ever cheaper - especially when the dual-layer fellas come in. Meaning that it may be the case that fewer players support (S)VCD in the future.
If you do go the DVD route, I'd second the burning at half D1 resolution - more is overkill and a waste. It then means you can get around 4 hours of video on one disc.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I will probably put them on dvd's then. I think it makes a little more sense because I can a lot more episodes on the dvd. Thanks for the help guys.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
