I have a P3 750Mhz 256RAM IBM (T21) lap top with a DVD-ROM.
Tried to play DVD with Power-DVD, but it pauses every few seconds
and impossible to watch!
CPU or software issue?
Thanks.
playing dvd's on your computer takes a lot of processor and graphics card power. a 750 mhz cpu wil most likely having difficulties with handling a dvd movie. you may try with a different player, but this will doubtfully give you better results...
SkrellK-a 750 mhz cpu wil most likely having difficulties with handling a dvd movie.
I am running a AMD 850mhz desktop pc and my dvds play perfectly, with a 5.1 sound card! I also have a p2 300mhz with a 4x dvd rom and a 16mb 3d card that plays just fine. Speed is not the sole determining factor in smooth dvd playback. Your codec, video card, and dvd drive are all important. If you have a good, stable system dvds will play in just about any system (I believe your supposed to be able to play dvds on a pentium 1, though I wouldn't recommend a pc that slow).
Are you playing a commercial dvd or a burned dvd? if it's a burned dvd, then is it labelled? sometimes labelling a disc can cause the disc to be unbalanced which creates the kind of playback you're seeing.
I have a thinkpad 770z (only PII) and it was doing the same thing. I purchased a margi dvd to go pcmcia card and it works perfectly. They go for as little as $10-15 on ebay. I recommened this as a solution. This way the dvd wont pause because you arent using your system memory to process video, all the video playing is through the margi card.
Lap top audio doe not work
By romanstopme in forum ComputerReplies: 2Last Post: 8th Nov 2008, 13:43 -
Lap Top & Internet Question
By DuBsTaR in forum ComputerReplies: 5Last Post: 10th Mar 2008, 18:34 -
Lap top to pc
By LabanB in forum ComputerReplies: 8Last Post: 3rd Feb 2008, 08:57 -
dvd +r made on lighton 5001 can't be read on desktop or lap top
By skydiverbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Jan 2008, 14:02 -
Can't play dvd on my lap top!
By BSarte in forum Software PlayingReplies: 2Last Post: 16th Sep 2007, 07:43
