  1. Hi! Can any body help me with this problem. I try to convert XVID.AVI file to DVD using DVD2SVCD version 1.2.2 b1 with Cinema Craft Encoder SP V2.67.00.27 every thing works fine I finish the convertion. now I have a DVD-movie but one problem When I play the movie(DVD) the scene it's in slow motion it's not real time. the movie move slow not like the source XVID it play normal movements. I dont understand help me please. I need your advise. If theres any settings or info that you can give me, I highly appreciated.
    TNX!
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    well, first of all, your using dvd2svcd. you want to convert avi to dvd, not dvd to svcd, as the name of the program suggests. Just use TMPGEnc to convert your avi file to dvd there are lots of guides on the left.
  3. Please don't post the same question in multiple forums in the future.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    canada
    Grimey,dvd2svcd can be used to encode to dvd,cvd,vcd and svcd,as to the slow motion problem have you installed the newest xvid codecs?Try encoding again if you install the newer codecs.
  5. Sorry! for posting the same question in multiple forums.
    I didn't know that this forums is monitored very well. Unlike other forums I'v had been. It takes weeks before I get answered.
    TMPGEnc Plus tooks too long for me, and quatility is not so good as CCE. I also tryed MainConcept MPEG Encoder it also tooks long time. I use normaly Super DVD Creator 7.0 for to conver but with this xvid I got then audio syncronisation problem. But if I use TMPEnc Plus I rather then use TMPGEnc DVD Source Creator it works also fine but I got PC crush my Pc just stop working and need to reboot. That is why I use DVD2SVCD I dont get Audio problems. I maybe later go for Pentium.
    About installing new xvid codecs, I dont think that will solved the problem
    couse when I play the xvid avi file it works normal there is no problem, so to my conclution it relays maybe to my CPU it self or the encoder settings.
    Then again please help me to solve this.
