    Mar 2002
    Hawaii
    I put together my new work computer mostly without a hitch. However, Internet Explorer disappeared from the desktop, after doing some OS updates. I tried reinstalling it, but the icon still wouldn't appear.
    Other than that, IE works fine, but I have to use the quick launch icon. This is the second time this happened. The last time, it happened with my home computer, so I just reinstalled the OS from scratch. If possible, I would like to avoid doing so with my work computer.
    Is there a setting that I can adjust, to make the icon appear on screen again? I can add a shortcut, but I'm looking for the original icon that should be there.
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Right click on the desktop and goto properties, its inthere somewhere to put the iconback.
    In the mean time rejoyce that its gone and go get Firefox. lol
    USA
    If you are looking for a version of the IE icon without the shortcut arrow, you need to modify the registry. It's not really worth it. But if you must, do a Google search for 'restore IE icon to the desktop'.
    Mar 2002
    Hawaii
    Thanks guys. I downloaded the registry hack. I was concerned that something was wrong.
    I'm assuming that it's part of the security features that are installed with sp4 and this happens to everyone. Or am I wrong?
