A friend of mine has a standalone player that, according to him, it should play dvd-r only, however it plays some dvd+r's.
Is the player hacked?. A coincidence?. A picky player?
Maybe he thinks it only plays dvd-r but it actually plays dvd+r as well!![]()
Anyone with the same experience here?
Give a person a fish and you feed them for a day; teach that person to use the Internet and they won't bother you for weeks
Have you noticed that a slight tax increase costs you two hundred dollars and a substantial tax cut saves you thirty cents? -
Many players are rated to play DVD-R but not DVD+R. That generally means that it wasn't TESTED for DVD+R.
In all likelihood, it will play DVD+R just fine.
Regards.Michael Tam
w: Morsels of Evidence -
coincidence, picky, lucky...may just depend on how old the player is. I have a 4 yr old Toshiba SD1600 that so far will not play +R at all. I have 2nd newer Toshiba that will. Slightly newer models than mine may be just fine. So even though it may not state it and may not have been tested, your friends player may be new enough that it does work.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 15:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 12:30
