I think I pretty much have the menus figured out in Author 1.5, with a few exceptions.
First I can't figure out anyway to delete text once it has been entered. I have even when to the advanced edit where you can move things around and resize things but still can't figure a way to delete the text.
Second I create a Main Menu page with the appropriate chapter and play buttons and then go to the track menu to setup menus for the tracks. When I come back to the Main Menu find it has changed to match the track menu. As I saved the main menu before going to the track menu I reload it from the drop down box and it is back as it was, only to find now the track menu has changed back, so once again edit it, and start all over.
I can't seem to make changes to the Main Menu without affecting the track menus and vice versa. I am sure I am missing something simple here but sure don't know what it is.
Thanks for any help.
Results 1 to 1 of 1
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56
