I've got 2 PAL mpg video clips that I want to convert to NTSC and burn onto one dvd. I loaded the files into tmpgenc dvd author and it says they are MPEG2 480x576 25 fps 4:3 PAL.
Suggestions on how I can convert this from PAL to NTSC?
Thanks!
Darkcyber
There are five PAL/NTSC conversions guides came up after I look in the
' HOW TO ' > ' ALL GUIDES ' > ' HOW TO CONVERT PAL TO NTSC / NTSC TO PAL ' .
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
Simple and easy? -
Thanks! I''ve already read over one of the guides, may be the same one you posted and trying to do it now. I would like to convert both of these files in to NTSC and then merge them together and burn them onto 1 dvd.
I may be asking to much...may be to large
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
