I've backed up many DVDs with DVDBackup with no problems- then today I get two discs in a row that have given me errors!
First, "Treasure Planet" stops, saying taht Title 2 cannot be processed.
"Poolhall Junkies" gives the same error, this time with Title 3.
Any suggestions on how to bypass this?
Thanks.
I had problems with Treasure Planet when using DVD Backup. I now use MTR(MacTheRipper) it's great! I have had no problems backing up my movies. Give it a try and see if it helps you out.
If you still want to use DVD BackUp, have you tried to just back up the problem title set by itself? I have had problem DVD's in the past and ripped the DVD (minus the title sets it says it can not back up). Then gone back and selected the title set that had a problem and only ripped that one. When you place it in the same folder it will ask you if you want to replace the existing one ... yes you do. See if this works for you. If not MTR has worked great for me.
Looks like MactheRipper is the winner-- backed up both discs without a fuss.
"The Station Agent," however, is another story. I get "READ FAILURE" and "Mirror of Title Set 1 failed" messages. -
This post is too new for you to go start another one just simply for this last issue
please try not to cause too much confusion. I posted in the other one before i saw this so ill leave it open but from now on, keep topics in teh same post
just beceause its on the 4th line down doesnt mean you wont get a reply -
Ah, dirty disc was the issue. Thanks for the reminder- should have known better.
You're correct about the separate thread-- please feel free to delete it if possible.
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
