what im looking to do is have a slideshow that that has a small screen within thats playing something else
is there any software that can do this
been searching the web but i my searchs arent turning up anything
this will end up a bit like an advance motion menu except it run for 15 mins
tried with dvd lab to create it as a long motion menu but there seems to be a time constraint in it
need info as fast as anyone can help
as tryingh to get this ready for midweek for a mate
you are wanting to do a picture in picture...if you are still searching for "how to's"
Adobe premiere is the easiest I think...but expensive if you don't already have it.
Simply....in adobe...
Put background in video 1, the video to appear smaller in the corner in video track 2
apply the transform filter, adjust size and position to where you want it
apply the clip or crop (clip I think, always get those 2 confused) ANY way, select your fill color to pure blue (red = 0, green = 0, blue = 255) and move the edges into the edges of your smaller video picture.
Now go to the transparency settings, select "blue screen" and away you go.
Pinnacle Studio 8 will also do it but you have to be fairly familiar with S8 and I certainly do not endorse it.
It is not as easy in S8, as S8 is a linear video editing software. But it can be done with motion tumbnails and it looks alright. As I said, I prefer adobe, it's easier and IMO looks better and is a hell of a lot easier to change if you want to adjust anything.
You are looking for a "Non-linear" video editing software and you are wanting to do a picture in picture. -
AviSynth is the cheapest. Check out the guide on this site to do it. You will probably need Virtual Dub too.
Hello. -
A really good idea, if you want the slide show with screen to look really classy, is to create a movie in Flash and import the mpegs to play on the screen, then send the entire thing to an AVI file, which can then be converted to a DVD compliant stream.
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
Freeware App To Change Video File Size, But Not Video Or Audio Codecs
By LouieChuckyMerry in forum Video ConversionReplies: 4Last Post: 19th Jun 2010, 09:06 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03
