I have tried to integrate a wireless Access Point (802.11g) to a normal TV cable using a T-joint (one side of the T-joint connects to the access point, one side connects to the TV cable which connects to the antenna located on the roof of my house for receving TV signal, and one side connects to the TV cable which connects to my TV inside my room). The wireless Access Point has also been connected to a modem for Internet access and is located at the ground floor of my house. Inside my room, I have used a 2.4GHz two-way splitter to connect the TV cable (which connects to my TV) and a 5dBi antenna trying to get the wireless broadband signal from the access point. However, it seems doesn't work well (I need to watch TV and go to the Internet wireless using my laptop at the same time). Can anyone please tell me how to make it work and where can I buy the required equipment. Thanks so much.
I think you're lucky you haven't burned up your access devices. It's the wrong impedance, the wrong frequency, the wrong amount of RF power. Noise on your cable wire would also interfere with this, along with 60HZ hum, static discharges, etc. If you have problems with wireless transmission, you should use a higher power access point.
Wireless Internet Connection Questions
By hech54 in forum ComputerReplies: 11Last Post: 28th Nov 2011, 10:38 -
cannot connect to internet via router hardwired to pc yet get wireless
By ultrarunner in forum MacReplies: 17Last Post: 29th Sep 2010, 15:19 -
Wireless Internet
By RustyBob in forum Off topicReplies: 5Last Post: 21st Jun 2010, 23:31 -
burner causing problem with wireless internet
By zerocoool in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Jan 2010, 02:19 -
High-speed internet through wireless network? Help!
By Super Warrior in forum ComputerReplies: 7Last Post: 18th May 2007, 12:34
