I recorded a 16x9 movie from my HD Directivo to the JVC DR-M10S using a DVD-RW in video mode. I was hoping that it would set the proper flags so it would play back properly on a 4x3 set. It didn't work. My understand is that the JVC is supposed to automatically set the flags based on the format of the source. Has anyone tried recording from a HD Directivo or have any other ideas on how to get this to work properly without having to copy the DVD to a PC and use Ifoedit to set the flags and then re-burn. Is there anyway to force the 16x9 flag on the JVC? Thanks.
Jay
stressbuster,
Could you give more specifics? Like:
1. What is your 4x3 TV set? Does it have 16x9 mode (Auto or Manual)?
3. How is your JVC set up? 4x3 Letterbox or 4x3 Pan & Scan?
It may be couple reasons.
1. Your HD Directivo box doesn't send 16x9 flag when downconverting to 480i.
You can check this by opening VIDEO_TS.IFO file from your recorded disk in IfoEdit. If it doesn't say 16x9 Pan & Scan and Letterbox for that title, it means your HD Directivo doesn't send that 16x9 flag, and it means SOL. But, if your 4x3 TV has 16x9 mode you can manually switch to it.
2. Your JVC is set up for 4x3 Pan & Scan.
Check the set up of your JVC. If it is 4x3 Pan & Scan change it to 4x3 Letterbox
I recorded one tape with my Sony D8 cam in 16x9 mode. Then I recorded the video to JVC via FireWire. After ripping disk IfoEdit showed 16x9 Pan & Scan and Letterbox in VIDEO_TS.IFO. It means my Sony D8 cam sends 16x9 flag through FireWire. My JVC is set up for 4x3 Letterbox.. Disk played with black bars at the top and bottom, letterboxed, on my old 96 Panasonic TV. -
Originally Posted by kabanero
Jay -
Originally Posted by stressbuster
It leads to the conclusion that your HD Directivo doesn't send 16x9 flag through S-Video when downconverting. You can call their tech support and ask about that.
Recording in 16x9 (Widescreen)
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th Aug 2009, 14:09 -
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 04:08 -
JVC DR M10S, DVD-RW 4X, Media
By pepegot1 in forum MediaReplies: 6Last Post: 27th Mar 2009, 08:21 -
JVC DR-M10S "Loading"
By Siperian Monkey in forum DVD & Blu-ray RecordersReplies: 25Last Post: 12th Oct 2008, 08:22 -
Journey of a Refurbished JVC DR-M10S unit....
By BrokenOne in forum DVD & Blu-ray RecordersReplies: 61Last Post: 4th Jan 2008, 20:14
