I got a bunch of movies on crappy DVD+R's they skip and freeze near the end maybe the last ten minutes my question is can I copy these Movies from these crappy disc's onto some good DVD 's and have the skips and freezes gone or are these movies that skip and freeze now garbage ?
Results 1 to 16 of 16
Well it doesn't hurt to try. It will work if your DVD-ROM can read the disks correctly. Chances are it will read the disks better than your DVD player so it might help.
Skipping near the end of the disc sounds like bad media to me as well. Just remember though....they are not bad media because they are +R....they are just bad media. If they read(with no errors) and play well in your computer it may be that your standalone DVD Player does not like +R's. I would definately download DVDInfoPro and do a read test on them first....no use wasting time on them if they really do have bad data at the end.
Hey I tried the same DVD in my Computer and it seems like it was fine, I wasted $80 on these DVD's and alot of time, dam I'm pissed thanks guys.
Did you by any chance apply any sticky labels to your DVDs? Lots of people have reported skipping towards the end on DVDs that have been labeled -
The issue happens on set top players but not so much on DVD Rom drives...
Could be the explanation: labels causing the player to mis-behave.
Cheers -
If the movies behave in the computer, you CAN, in fact, just rip them to your hard drive again, and burn them back to better media.
- Gurm -
What I would do, some retailers do a dvd "tester" pack so you can find out which media is the best for you, could be worth investing.Originally Posted by Gurm
If they play fine on ur PC just re-rip and reburn. I have an original copy of Saving Private Ryne that started to have artifacts appearing when played on my standalone players and was getting worst as each year went on. Thought I had to buy a replacement copy but just as a last resort I used my DVD rom was able to rip it to HD so I could make BK copies.
I have the same problem..
I use Great Quality 4x Media..
and it skips or freezes..
but thats on movies that are 2 hrs. and over..
I have no problem with movies below 2 hrs.
if I used Ridata Ritek 4x RICOHJPNR01
then I wouldnt have no problems ????
plus I need to upgrade the firmware on the HP 300 n.. so ya think it might help?"What It Do"
Huh ????? -
Am I the only one that finds it ironic that "Great Quality" media are actually cheap crap?
- Gurm -
I had the same problem to. seems like even with brand name media u can have this problem. It really sux and i've been lucky lately.
That's how it's been since the first "Great Quality" CD-R's came out back in like 1997 or so.Originally Posted by GurmWant my help? Ask here! (not via PM!)
Originally Posted by Scottie
You many need several programs to run these copies. I've noticed that sometimes Shrink will work where Clone will not and Decrypter will work when Clone doesn't. Some react differently to data read errors.
Also try Intervideos DVDCopy V1 or V2... both work well at straight DVD5 copying. -
You should be able to stick the DVD+R in your DVD drive on your computer and copy the VIDEO_TS and AUDIO_TS folders to a directory on your hard disk. Then use your recording software to record them on to a new DVD+R. I don't beleive that you need to mess with ripping nor decrypting software. As far as your computer is concerned this is just a basic data disk.
I have never tried this so let me know if I'm nuts.Ted Rossin
http://www.tedrossin.0sites.net/ -
I found that all my DVDs skip if I write them with Nero. If you make an ISO of the disk an burn with Alcohol it works perfectly! By the way I use DataWrite for but CD and DVD media very cheap and reliable I get DVDs for roughly the same price as CDs.
Working to clean-up crappy DVD source, any suggestions appreciated.
By dragonkeeper in forum Video ConversionReplies: 10Last Post: 6th Oct 2011, 10:34 -
Joboshare dvd copy produced a bunch of files I dont understand
By rocks911 in forum DVD RippingReplies: 1Last Post: 31st Aug 2011, 22:38 -
i have a bunch of tv shows and i would like to combine them onto 1 dvd
By shadowm891 in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2010, 16:16 -
Obama bought the President of England a bunch of DVD that are region 1 LOL
By vatkat234 in forum Off topicReplies: 4Last Post: 20th Mar 2009, 20:15 -
Why am I getting crappy DVD encoding? (interlace problems, etc)
By timmus in forum Authoring (DVD)Replies: 15Last Post: 14th Apr 2008, 10:23
