I have a problem.
A friend of mine has given me a video file which is said to have 2 separate audio tracks (or channels... I dunno how you call them). Is there a program that can let me listen to only one at the time, or if there is a way to exctract the two tracks, so I can remake the file with only the one I want (like with virtualdub)?
tracks and channels are two very different things. tracks are like soundtracks to a movie, like english and french tracks. channels are signals sent to speakers, like a left channel and a right channel. which are you talking about?
dodoss,
I'm almost certain you have a mpg with 2 mono audio channels.
I've seen one on a Japanese anime vcd, one channel is in Japanese
and the other in English.
If your mpg is indeed on a vcd, just put it into a DVD player and select
the left or right channel to get your desire language. Why go thru all
the troubles?
If what I assumed is incorrect, state more informations on your next
post .
The link below was someone had a similar situation. See if it fit your need.
https://www.videohelp.com/forum/viewtopic.php?t=215407&highlight= -
you're right sorry... I'll give you some more information, at least about the file. It's an .avi file encoded in divx and mp3...
some suggestions? should I follow the same procedure showed in your old post?
Videoing on DV but recording separate audio
By fairysdad in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2011, 13:46 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Avidemux: How to separate Video from Audio
By DarkPhoenix77 in forum MacReplies: 1Last Post: 24th May 2010, 02:30 -
Canīt properly separate audio from video
By dexter30 in forum AudioReplies: 2Last Post: 29th Oct 2009, 20:44 -
Ripping DVD Audio Into Separate Tracks
By stovk in forum AudioReplies: 0Last Post: 27th May 2008, 15:10
