Hi,
I am at the moment trying to find the best method of making high quality MPEG 1 files and am experiencing the following problems.
I have captured the AVI file that I am trying to encode using ULEAD DVD MovieFactory. This programme only seems to capture AVI files at 360 x 288 is this right?
Problem when trying to use LIGOS LKSX-MPEG Encoder:
When I try and add the input file to the encoder I get the following message "Failed to open AVI video stream or file format error. Please specify valid input file name and directory".
When I make the MPEG file using TMPGEnc I get a nice file except I can't find a way to remove theinterlacing lines which show up badly on movement.
Lastly none of these or the encoder in MovieFactory seem to be able to produce the quality I get from Cleaner which is very much against everything I have read.
What am I doing wrong?
Results 1 to 1 of 1
Take care
Dave
Dave Knowles Films
Southampton - UK
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 20:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 23:32 -
Problems with Vimeo Encoding
By Xenon77 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Apr 2009, 13:04 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 13:50 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30
