Right people, I have an odd dvd which has no ifo_1 so shrink and the like will not read it. What program can I take vobs and reauthor with valid ifo's ?
VOBEdit might be able to demux the .VOB's for you without the IFO's. If not, try saving the VOB's to your hard drive, renaming them with the.mpg extension and then demuxing with TMPGEnc MPEG Tools or any .mpg demuxer. Then author a simple DVD with IFOEdit. If you need chapter stops, load the demuxed files into MPEG2Schnitt to pick the frame numbers and create a .txt file prior to authoring in IFOEdit.
Or, after renaming the VOB's to .mpg, author with TMPGEnc DVD Author without demuxing first.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
