What is the (practical) difference between these "quick Presets"?
Results 1 to 9 of 9
From the Readme file:
fastDVD uses another engine and encodes twice as fast as DVD presets. It is slightly less standard-compliant, but if it works for you, you could prefer it for the speed and the slightly better image.You can store on a 4GB DVD media about:
DVD-hi 145 minutes of video at DVD quality
DVD-lo 4 hours and 10 min of video at near SVCD quality
KDVD: 5 hours of video at near SVCD quality
Hrm that's a little strange - I consistently get 5.5 to 6 hours for the DVD-low bitrate preset (the preset defaults to 2300kbps). This is for downloaded Simpsons episodes though. Not that I'm complaining - I can fit half a season per DVD this way!
I don't understand.Originally Posted by thoughton
You encode them one episode by one episode into mpeg2 files and then sizzle is able to make all these seperate files into one?
Yah. Sizzle is an authoring app which takes a bunch of mpeg2s and turns them into a DVD format (video_ts folder containing vobs) which you can then burn onto DVD-R.
KDVD and nero
By silkk504 in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2008, 16:49 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
KDVD Help
By dbanga in forum Authoring (DVD)Replies: 6Last Post: 25th Jun 2007, 20:39 -
Help Xvid to KDVD
By dbanga in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 16:27 -
burning kdvd?
By syun_ukiya in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2007, 05:14
