Hi, I've just made a back up of SWAT using dvd shrink in total the whole process took 5hr 59min to complete, authoring to HD ect.
This seems a long time for a 1hr 50m film enc menu ect..
My system is pent3 600Mhz 256ram
any opinions 8)
Buy a new computer. As you've discovered, you can use Shrink on a slow system, but it takes ages. I can do a complete re-author and shrink to main menu only in under an hour, even using deep analysis.Originally Posted by giraffe
Your best answer would ideally come form another PIII owner. My PC (AMD XP-M2500 o/c @ 2.34GHz) will do it in an hour and a half, including ripping and burning time, using deep analysis. MHz for MHz (and I know this isn't a fair comparison) my PC is four times quicker than your one, so quadruple time = six hours.
It seems that your encoding speed is average but as I say, wait and see what other people who know more than I do have to say.
Cobra -
What else is it doing as well...
XP needs 256 ram and if thats all you've got it aint going to help (you only say 128 in comp specs) My other Pc a duron 750 takes approx 2 hours to do a film but its not running anything else, bare xp install 512 ram NO background programs.Not bothered by small problems...
Spend a night alone with a mosquito -
Thanxs guys
i'll do some more tweeking to try and speed things up but it's prob down to the system i've got..
just a thought my settings are set to PIO ONLY on all my primary /secondary ide channels, when they are set to DMA nero and other burning software do not respond and freeze up
I just noticed on http://www.mrbass.org/dvdnewbie/ that the setting should be set to DMA on all channels , why does this not work on my system?? -
Yes, you'll get a better performance with all your drive set in DMA.
Try downloading you latest drivers for your motherboard/chipset.
When I try to Backup DVD on Shrink...
By lblaker in forum DVD RippingReplies: 10Last Post: 24th Mar 2010, 21:08 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Saw 4 does not backup using DVD Shrink
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2008, 04:11 -
DVDFab 4.0.2.0 Beta backup crashed Shrink - fixed(sort off)
By pchan in forum DVD RippingReplies: 1Last Post: 21st Dec 2007, 10:04 -
Question about time it takes to backup hd-dvd
By ultraman36 in forum DVD RippingReplies: 0Last Post: 6th Dec 2007, 14:18
