I just recently downloaded a movie off the net and I just found out it is a PAL movie, which means I can’t watch it on my DVD player because my DVD player only accepts NTSC. This is all the info on the movie I downloaded MPEG2, PlayingTime=1916.360s, Bitrate=1882400bps, PtsOffset=0733s, 196593 packets
Video Stream: Motion Video, 480x576, 25fps (PAL), 2556kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
Iam very new at this and really don’t know what any of this means, I tried using one of the guides for converting PAL to NTSC and couldn’t figure out how to do it. Iam going to be making an SVCD out of this file (iam putting it on a CD-R) But I need to know how to convert everything. Iam really confused with all of this, if any of this makes any sense then please help.
-Jay
Results 1 to 9 of 9
Are you sure your dvd player cant play pal svcd?My 2 year old ntsc apex 1500 can play pal scvd with no problems,try burning on a cd-rw and test it for playability.
I have an apex also and I tried playen a copy of the movie and the movie ended up kinda lookin black and white and had thas black bar in the middle of the screen that would bob up and down.
I've used TMPEG to encode PAL to NTSC and it seems to work. TMPEG will show PAL in the advanced tab,be sure to select NTSC in the video tab.
DVD players I know convert PAL to NTSC
Sampo 612
Norcent 302V
Philips DVP642
Koss KD305
Daewoo 5800 -
You should use DVD2AVI to get a D2V project file. This will also separate your audio file.
Convert the MP2 to PCM WAV. Then convert that PCM WAV to a new PCM WAV using BeSweet and the PAL (25fps) to NTSC (23.976fps) option.
Now feed the D2V project file into TMPGEnc as your VIDEO SOURCE and your newly created PCM WAV file as your AUDIO SOURCE.
Make sure you use the SVCD NTSC FILM template in WIZARD MODE. You will have to select NON-INTERLACED as your source and select DO NOT FRAME RATE CONVERSION.
That should work but if the PAL source is INTERLACED then you have to use Xesdeeni's method which requires using an AviSynth script.
There are guides that cover the details of all this.
Read my mini-guide here in this thread:
https://www.videohelp.com/forum/viewtopic.php?t=228302
That is for doing PAL to NTSC although like a said it will mostly likely only work correctly if the source is PROGRESSIVE 25fps PAL.
If it is INTERLACED 25fps PAL then you need to look at Xesdeeni's guide. I have also posted a lot of stuff on that. Use the search option on the website for my posts and Xesdeeni's guide is in our GUIDES SECTION here.
My file is an PAL mpeg 2 file and I think all the information left by people in this post is for converting PAL avi files. Anyways the post left by FulciLives seems pretty helpful, but it seems like its only for converting the audio, don't you need to convert the video to, also I think this guide is for converting a PAL DVD to a NTSC DVD and iam trying to create an NTSC SVCD. Iam not sure if any of that made sense. Still kind of confused and seeking help.
-Jay -
Did you even read that guide I posted a link too?Originally Posted by spiralnebula42o
It is about as simple a guide as there is!
Just treat the MPEG-2 file you have like a VOB file. Run it through DVD2AVI as I've already said.
I can't see where you are confused ???
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
