proxyx99, thanks, that does look like a nice test pattern. I assume when you say Ulead, you mean VideoStudio? If so, I'm not sure I want to plunk down the $100.
However, thanks to gshelley61, I found that I do have the THX test stuff on my kids' Ice Age DVD. I did a bit of testing with it the other night, trying to decide which of my VCRs does the best job of recording. I might have to start a new thread on that topic.![]()
Results 31 to 35 of 35
Great, glad I could help. The THX test patterns don't tell the whole story, but will reveal any distortions and flaws that may be occuring when processing or recording a video signal. Plus, they are very helpful for setting up your monitor/home theater display.
Oh, don't forget to rip a backup copy of the test patterns sequence with DVDShrink or something... they are copy protected, so you can't record them right off of the Ice Age DVD. Running the patterns through a TBC or other copy protection defeater adds another layer of processing to the video signal. -
Another way would be to import several BMP's into your video editor (like the one I posted) make a few min. avi and mpg with pattern changing every 30 sec. or so coupled with some high quality video material that may be found on demo discs by Sony, Pioneer etc. that is used to show plasma TV capabilities. If you need a test bmp file PM me.
Originally Posted by gshelley61
Originally Posted by proxyx99 -
OK...I have one last screen cap to post. This one comes from the Mitsubishi HS-U781 that I had in the master bedroom. After setting the "perfect picture" to edit, I like this more than I originally thought. Not quite as sharp as the Panasonic, but close, and a little less noise, I think.
turn off/disable VCR On Screen Display for capturing
By lesleyjudy in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2021, 07:01 -
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 20:13 -
Screen Cap from video
By eliqush in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2009, 04:52 -
Capturing screen image to video - using dedicated card - what software ?
By ullteppe in forum Video Streaming DownloadingReplies: 10Last Post: 12th Oct 2008, 10:34 -
JVC VCR - how to defeat the blue screen?
By theaveng in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2008, 06:22
