I took my avi to dvd2onex and followed instructions on the tutorial. I created a folder with dvd name and put in VIDEO_TS and AUDIO_TS. I burned in Toast 6 under data and came out with a disk that my dvd would play but with no audio. Very confused as I have been trying to follow instructions now for 2 weeks to get one 686 megabyte avi file to burn to dvd. The avi will play perfect with mplayer. I am just about fit to be tied with this sh#*@*^. anyone got a clue? Thanks
"Enjoy every sandwich" Warren Zevon
Read the tutorial again. DVD's use mpeg2 files not AVIs. The audio should be either PCM or AC3.
You're right it is PCM. I encoded the avi using toast and saved as disc image, then imported that into dvd2one. I checked the PCM and let dvd2one do it's thing. Then burned as data DVD in Toast. Just can't figure why the resulting DVD had no audio.
"Enjoy every sandwich" Warren Zevon -
Where was the last step in which you had the audio? Was it when you had just an AVI? When you mount the Toast disc image (before DVD2One X) will it play sound in Apple's DVD Player? I doubt that anything is happening at the requantizing stage as that deals with the video. My guess is something happened when you dropped your AVI in Toast.
You are absolutely right again. It will play with no audio in dvd player. Wonder what I did wrong in Toast?
Toast uses Quicktime to encode the video. Try using something like FFMPEGX or MPEG2Works to encode audio and video separately. In this case you could also rip the DVD into a single VOB (using Yade X) Demux it (using FFMPEG X or BBDemux) and create mp2(PCM) or AC3 audio using FFMPEGX or MPEG2 Works. This will allow you to keep the already encoded video, and remultiplex in a working audio track. MissingMPEGTools will also do the job and is free. Download it from RNC's site.
And if it's a avi file originally, then there are hundreds of formats the audio could be.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
Deleting Specific Audio in Toast 10 Titanium?
By JonnyPhoenyx in forum MacReplies: 1Last Post: 8th Mar 2009, 14:10 -
Did toast 9 do away with audio export?
By stanislawski in forum MacReplies: 2Last Post: 1st May 2008, 03:36 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 02:05 -
.MOV to VIDEO_TS How? [ffmpegX] [DVD2ONEX]
By bonespur in forum MacReplies: 5Last Post: 26th Jul 2007, 09:48
