How do I join as one, two quicktime files that I have created separately in imovie (one of the days scuba dive, the other of the island), so I don't need to reconvert my standard introduction every time I produce a VCD in Toast 5? I need to create one seemless movie.
Cheers Steve
Just encode the both files as VCD mpeg1 files. Then join them with mpgtx-1.1 (cli to for osX). It works fin for me, also with SVCD mpeg2 files.
/Jesper nilsson -
Thanks Jesper for your help. Can I use mpgtx-1.1 in OS 9.2 or only in OS x. Also where can I get it from?
Cheers Steve
/Jesper nilsson
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
I dont want to bash you or something. But there is really no reason to stick with that old os9. Everything is better with osX. I dont even use classic mode.
And dont mention monney. Download a p-copy of it. Thats better than turning over to wintel.
So maybe you got the answer: no os9 version. And versiontracker.com has it for dist. -
I have moved over to OS 10.1.1 (for the second time) but have a few problems. I produce scuba videos in imovies and burn VCDs in Toast 5 on my ibook. Toast beta works with IDE recorders that are set to Master and have their own bus. (This means that the internal CD-RW drive of my ibook won't work.)
Creating movie (mov) reference files with ffmpeg or ffmbc
By musicman in forum Video ConversionReplies: 3Last Post: 6th Jul 2012, 18:40 -
Creating iDVD Movie
By wimbly11 in forum MacReplies: 13Last Post: 10th Aug 2011, 10:25 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 16:00 -
creating a dvd using idvd 5 of a movie around 3 hrs?
By tab75-13 in forum MacReplies: 2Last Post: 1st Jun 2007, 06:12 -
Creating Movie
By Adarsh2211 in forum Video ConversionReplies: 2Last Post: 28th May 2007, 22:42
