  1. I am using TMPGEnc Author 1.5 to make a DVD from a captured video tape. When I open the file it says " A video sequence header is necessary for every GOP in a standard DVD." How do I go about adding that?
    Thank you
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    use restream
  3. I'm a Super Moderator johns0's Avatar
    canada
    You can also run the mpg thru tmpgenc/mpeg tool/merge and cut and choose mpeg-1 video-cd as output type.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    he is making a dvd
  5. Member daamon's Avatar
    Melbourne, Oz
    Thank you
    Just for future reference, if you've encoded the captured video tape using TMPGEnc (an assumption) then the setting you need to make in TMPGEnc to avoid this is:
    1. Click "Setting" bottom right of TMPGEnc window.
    2. Go to "GOP Structure" tab.
    3. Set "Output interval of sequence header" = 1.
    Hope that helps...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  6. I'm a Super Moderator johns0's Avatar
    canada
    he is making a dvd
    Yes i know,thats one way of fixing a mpg1 file that tmpgenc dvd author wont accept.
  7. Yes i know,thats one way of fixing a mpg1 file that tmpgenc dvd author wont accept.
    It works for DVD, as well - select Mpeg 2 Program, instead of Mpeg 1.
  8. I'm a Super Moderator johns0's Avatar
    canada
    Yes,just depends on the type of file,i was using mpg1 as an example.
