Any really good DVD-Rs around 8X that are compatible with the DD0401 (1.5 firmware so it says 8X -R)?
I ran a search but didn't see any.
Thanks,
Pete -
Wow, you sure do have a lot of questions about your Optorite drive. I would say that you should try the Taiyo Yuden 8x DVD-Rs. If those don't work, then I don't know what will.
Hi psal2,
For a list of support 8x media disc (based on the media code) see http://www.optorite.com/_english/web/1_product/2_spec.php?hID=2 .
Scroll down and you will see a link for the media. The file is in Excel Format, but a PDF will be posted later. If you are unable to view the file, please contact me at support@optorite.com .
If you are unable to get to the link above, do this (make sure to use IE):
a. Go to http://www.optorite.com/
b. Select the U.S. and then select Product Info or New Product.
c. Select the DD0401 drive, and then the specification link.
d. Scroll down and you will see the link for the list.
Thank you,
OptoRite Support -
<-----left column, dvd media or dvd writers.
Tell ya what, why don't you ask a big media store what to use? Also of them list what works with what media at what speed with what firmware. -
Originally Posted by OptoRite
Are you really Optorite support??? Where were you guys when I was having problems with my drive? Any hope for BitSetting support? -
Originally Posted by dfw3064
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 06:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
