Guys searched everywhere and cant seem to find the solution pls help.
I'm using Nero6 with all latest plugins and codecs, writing to a 4.7gb DVD.
Nero is telling me file size is 4.48gb but that its too big for the normal dvd.
My understanding is 4.48gb should fit.
What am i missing?
thanks for any help
EDIT: Damn you guys type fast.
https://www.videohelp.com/dvd.htm#1000
A single layer blank DVD actually only holds 4.37GB, which is equal to 4,700,000,000 bytes. The discrepancy between the actual size of the data on your hard drive and the size listed on the blank disk is because computers store data differently and manufacturers choose to list the higher "looking" of the two numbers.
If you right click on all the files you want to burn and view the properties you will see that they actually exceed 4,700,000,000 bytes.
My preference for determinging whether my project will fit on the blank is to open the VIDEO_TS.IFO in IFOEdit and hitting file/check dvdr size (something like that). It will tell you exactly how many MB over or under you are.
Anyone write Welsh?
By Compo in forum Off topicReplies: 8Last Post: 24th Dec 2011, 13:03 -
Write in the air...
By Quasar_wpg in forum EditingReplies: 1Last Post: 23rd Aug 2009, 17:42 -
how can I write to a DVD+R DL
By agent222 in forum Authoring (DVD)Replies: 12Last Post: 12th Apr 2009, 14:08 -
DVDAuthorGUI: How do I write?
By videohalp in forum Authoring (DVD)Replies: 1Last Post: 8th Jul 2008, 20:29 -
What Format did I write in
By TechJD in forum DVD & Blu-ray WritersReplies: 5Last Post: 30th Jan 2008, 19:24
