Is it possible to split a BIG movie file, encode it into MPEG format, so that it can be made into a VCD, then join all the small pieces again?
I will use HJSplit to split the files into small *.001, *.002, etc.
Then rename all of the small files to something like, mpeg.
Use TMPGEnc to encode the small renamed files to a correct MPEG format so that it can be made into a VCD.
After encoding all the files, then use HJSplit again to join em up to become a BIG file again, only this time it can be made into a VCD
I was kinda wondering if this would work since my computer's too slow to encode a really huge file even if i leave it for days. I'm kinda hoping someone would clarify this and tell me if theres any problems with it before i try it first hand.
All replies welcome!
use virtual dub or any other video spliting program depending on what type of movie file it is to split the movie.
split it in how many parts u wish
use tmpg to encode each part to mpeg
then use tmpg to merge the files -
So you're saying it IS possible right? If so i'm gonna try it, let's just hope i don't loose my BIG movie file! Thnx BTW!
Also if anyone has tried the above pls feel free to add your comment!
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
trouble splitting and joining with mp4box
By charlieship in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2011, 16:19 -
Avidemux for Splitting/Joining
By eskro in forum EditingReplies: 3Last Post: 29th Jan 2010, 11:44 -
Splitting/Joining files: new Freeware tool!
By Anonymous5394 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 15:38 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32
