  1. Hi,
    I'm a bit of a newbie. A friend and I have been debating the the quality of the video when converting the original .avi capture. Is it best to convert the .avi first to dvd (mpeg-2)? Or is there video degradation or lossiness, if I convert the .avi to mpeg-1, then later convert the mpeg-1 to dvd? Or is there no difference which route to take the .avi and mpeg-1 and dvd do not lose video quality when converting between the 2?
    I use TMPGENC for my conversions. I am converting a VHS tape, running through a JVC S9500U > stand alone TBC > Datavideo DAC-100 > Adaptec 4300 > Scenalyzer
    Apr 2002
    The State of Frustration
    Convert as few times as possible. Convert from AVI to DVD MPEG-2. Then author the MPEG-2 file to your BUPs, IFOs, VOBs. Burn these to DVDs.
    Hello.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    It's best to use the original AVI for the conversions.
    If you want to create mpg-1, go avi-->VCD
    For mpg-2, go avi-->DVD/SVCD
    Try not to go avi-->mpg1-->mpg2-->mpg1-->divx-->whatever
