HI all
I must confess to being a complete newbie to encodeing but if anyone can tell me where I am going wrong I would be most grateful.
I have downloaded a number of movies in the form of DivX avi files and am attempting to encode them to Mpg 1/2 files to produce VCD's /SVCD's. I cant seem to get past step one, as Tmpgenc always tells me that it cant open the file or it is unsupported.
Am I missing something ? (very probably)
have you installed the DivX codecs?
all programs installed under Windows will make use of these codecs once installed.
yo D_THOMAS are you able to view the divx movies on your computer that you downloaded because if u can then that means u already have the divx codec...and it is anotha problem
Goto the Tools section here and grab Divx4 and Kristal Studio Pack. After installing them you should be good to go.
Duh, Sometimes I'm amazed by my own stupidity !
I had downloaded the Kristal studio's codecs but ... had forgotten to install them.
Thanks for the pointers, I'll try not to be so dim in the future
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 10:45 -
TMPGEnc DivX conversion BLOCKED-LIKE avi
By visitor in forum Video ConversionReplies: 2Last Post: 26th Dec 2009, 10:32 -
Re-encoding some AVI files
By jr_dvd_ripper in forum Video ConversionReplies: 1Last Post: 25th Sep 2008, 03:43 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 14:24
