This is gonna be a real quick thread. I want a screenshot capture program so I can show off my desktop, etc like other people do on this forum. Instead of going to download.com and getting the first program I find which is probably gonna be loaded with spyware, I decided to ask you guys. Thanks.
Results 1 to 21 of 21
PrintScreen and then paste into your paint program de jour... there you crop, resize and adjust color depth. FREE
Thanks for both of your responses. Wow! Despite thinking of myself as being quite familiar with XP, I never knew of this Print Screen function. That is definetly what I am going to use. What do you guys use for capturing video screenshots. My WinDVD version doesn't seem to have a capture function.
A sample of what I accomplished:
from avi - VirtualdubOriginally Posted by 888888
from mpeg - VirtualdubMod
from dvd - PowerDVD- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
FYI:
Alt + PrintScreen grabs just the active window"Terminated!" :firing: -
Sweet Tip... since I have dual screens this will come in very handy.Originally Posted by thayne
Thanks -
Thanks for all the responses. I guess I finally found a use for PowerDVD which I uninstalled a long time ago. So thanks to housepig for pointing out the easiest option.
I used none other than Paint Shop Pro 8! I should try again, I might have done something wrong in the hurry.Originally Posted by flaninacupboard -
Ok. This one looks better. I used smart-size option instead of pixel-resize which is what cause those shitty results. Don't know why.
bless you, sir.... that's going to save me a lot of cropping when I have to re-write the company manual...Originally Posted by thayne- housepig
Housepig Records
out now:
I didn't know about the print screen funtion either...thanks.
I use the capture program from AnalogX. (www.analogx.com) it's really small, works great and it's free. Only thing I don't like is that it captures to BMP but I know that's for quality. Then I use photoshop to crop/shrink/edit. -
from avi,mpg,dvd,hdwmv,any video Media Player Classic.
ScreenPrint32
you can select what is to be captured like this:
just a thought
mastersmurfie -
and if you don't have / can't afford Photoshop, try The Gimp.Originally Posted by thayne- housepig
Housepig Records
out now:
I didn't know this one. Thanks. Like another said, perfect crops, saved time. I too write a lot of manuals and how-to's.Originally Posted by thayneWant my help? Ask here! (not via PM!)
here's one I just came across - haven't used it yet, but downloading now:
Scrapture.
nice thing about this one, it automatically saves your captures to an image file, no need to open an image editor and paste.- housepig
Housepig Records
out now:
I've been using Gadwin PrintScreen for a while & I really like it! (FREEWARE)
http://www.gadwin.com/printscreen/?prnscr~~~~~~~~~~~~~~~~
Thank You for Your Time!
DJ5A
ScreenShot
By drgt in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 14:10 -
Movie Screenshot Program?
By Junkee in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2010, 05:15 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Capture a screenshot from a video?
By ChaunceyK in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2007, 09:04
