I got 2 AVI's which i converted to MPEG using TMPGEnc (exactly the same bitrate, size, audio for both).
When i tried to merge the 2 MPEG's using TMPEGEnc merge tool, it said that the 2nd MPEG was unsupported by any other MPEG.
So i downloaded another MPEG merger program and used it. Worked a charm!
Opened up the merged MPEG in Windows Media Player - showed the correct playing time. Scanned through it - no problems! 1 hour, 43 minutes.
Until.... i want to make them DVD files. So i put them into TMPGEnc DVD Author - the playing time of the merged MPEG was 53 minutes (the length of the first AVI which i converted)
I also deleted the original AVI files (i assumed the MPEG was OK as i scanned through it without problems)
Is there any chance of me recovering these 50 or so minutes of lost video without the original AVI's?
Any help would be much appreciated!
Brian
Results 1 to 1 of 1
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
After converting to mp4, Ellion 950-s recognises disc, but not files within
By anlaoch in forum DVD RippingReplies: 3Last Post: 2nd May 2008, 09:06 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 22:15 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
