Is it possible to go from my PC to the I-Link in my recorder? I have some vcds i would like to transfer over to DVD and would like to do it that way. When i hook the cable up the PC recognizes that it is hooked up to a Sony RDR-GX7. When i put the VCD in my PC i don't get anything going to the recorder. Also have a number of cds with the extras on them that you can only play in your PC that i would like to put to DVD as well. Thanks for any help.[/i]
The i.Link on your DVD Recorder only accepts DV avi files. You need to convert your VCD to DV avi in order for your recorder to recognize it.
You will also need a program that will recognize and be able to write to your IEEE component.
DVD recorder chapters or use computer ?
By Kev75 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2008, 23:32 -
DVD Recorder to Computer
By ochsfamily in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Dec 2007, 09:37 -
My computer's screen to DVD Recorder
By mingul in forum Capturing and VCRReplies: 16Last Post: 16th Nov 2007, 01:39 -
By mingul in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 03:27 -
DVD recorder -> playback on computer
By blazejay in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2007, 12:22
