Hi guys
Please help me... the captured clips (mini Dv) are very dark in my monitor and editing results very difficult, but when I export to tape the final product the images are displaied in the Tv with the original brightness. I can't do some color correction to the clips after capturing because the result after export may be dummy, so what I can do ? where is the problem?
thanks a lot..
Gutzs
The problem is in your monitor calibration. You have the brightness/contrast set too low. You have a couple of choices
1. Calibrate your monitor correctly
2. Connect an external monitor and use this while editing -
Computer monitors and TV screens display things differently. It does not mean that your monitor is set up 'incorrectly'. Just that the video was made to look right on a TV screen.
My monitor is set up correctly to work with Photoshop, my printer and my digital camera and many videos appear too dark. If you change the monitor settings for these videos, then web pages and all kinds of other stuff will look wrong. It will be OK if you are using the system for video editing and nothing else...
For playback, your best bet is a player such as Media Player Classic or VideoLan that lets you adjust the brightness of the video.
For colour correcting during editing, you need to display the video on a TV screen -- either as you work, or output some test clips on a CD and play them in your DVD player.
Captured Video Clips
By Prepper in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 14:02 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum Capturing and VCRReplies: 4Last Post: 10th Jul 2009, 19:36 -
Windows Movie Maker - Why is there no sound after video clips captured?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Dec 2008, 10:45 -
Captured audio low/quiet/soft
By binister in forum AudioReplies: 1Last Post: 1st Dec 2008, 12:18
