I live in England, but while on holiday in America my friend gave me an old Compaq Armada M700 Laptop. It has a Multi-bay CD-DVD drive, At first it would only play region 1 DVD's, I finally found a utility which would change the region code, but then i bought another dvd drive off E-bay, so i can simply just swap the drives over.
I always back up my dvd collections onto dvd-r, they play on all my other computers and standalone I have tried DVD+R but they are no good for playback on the standalone dvd player.
Anyway, I found that the copied DVD's would not play well on the laptop, some would just burr away in the drive others would play then freeze stop and start and be jittery. I discovered if i made a copy onto a dvd+r they would play just perfect This occurred on both drives. So i have come to the conclusion that DVD+r must be an American choice and DVD-r an english choice, why can they not just stick to one media type
supertrooper
because -R is cheaper but +R has "lossless linking".
you think it's bad now? what till you have a DVD-/+/ram/hd-dvd/bluray/fmd/cd-r/rw drive
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Best FREE (not a trial) EASY software to convert UTube movies onto a DVD???
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2012, 01:37 -
DivX v/s Xvid trial and error now puzzled, read toward end
By adiktlost in forum Newbie / General discussionsReplies: 7Last Post: 12th Jan 2009, 20:37 -
can't get videos - trial and error (Using Grab++, WM Recorder, etc)
By bioshockfan24 in forum Video Streaming DownloadingReplies: 2Last Post: 29th Aug 2008, 18:29 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25
