    Apr 2002
    Taken over by Zombies
    I started to rip the Stargate-SG1 Season 6 DVD's a yesterday, but when I encoded w/ Gordian Knot (Video: XviD 2 Pass w/ Calculated Bitrate Audio: Mux 5.1 AC3 448Kbps), I find that the audio is out of sync with the video. When I encode with a 2.1 192Kbps AC3, the audio is fine (I determined this by encoding Season 1 DVD's). The Season 6 DVD's have a 2.1 192Kbps Dolby source, but it is the directors commentary version (It does, however, say in sync the entire length of the rip). I tried to convert the 5.1 AC3 to a 2.1 @ 192Kbps with BeSweet, but it still does not sync properly. So, I'm wondering if anyone has expierienced this problem, and what they have done to fix it. There was a topic about this exact DVD collection, but the reply was to use Gordian Knot to transcode the AC3 to a MP3, which I don't want to do. Also, is there a better program to recode my AC3?
  2. when you make a project with dvd2avi it will have the delay (xxx AC3 T02 3_2ch 448Kbps DELAY -113ms.ac3)
    add the delay when muxing,i suggest using vdubmod for muxing.
    sometimes dvd2avi doesn't give the correct delay,in that case you have to play with it to get the right delay.
    Apr 2002
    I actually think that it starts off in sync, but I'm not sure, and gets progressively worse (Although I'm not sure of this either). I really wouldn't want to have to mess around with it, but if forced, I will. Right now I'm trying to encode the file on my other computer, to see if that makes a difference. Still though, don't you think it's wierd that this only happens on 5.1? Also, is there a better program than BeSweet to change an AC3 file?
    Edit:
    When I went to encode on my other computer, I noticed the following differences:
